Home > Maintenance & Modifications > Yellow trim clips in door - Removal
HughN
Wales
What's the received wisdom on the best way to remove the yellow clips from the doors? Tenacious little things are resisting all attempts other than getting a knife blade under the edge....
Thanks,
Hugh
Post #585167 Sat Aug 10 2019 4:01pm
you do seam to have to break them into peices to remove them!
But if they are intact there is no need to remove them ?? ? ? Confused
fit solid black ones on the ends
Post #585170 Sat Aug 10 2019 4:49pm
Don't bother, just break them off, can be removed but usually damages them and can't re-use them anyway, as they are only a few pence each to buy not worth the aggravation of trying to remove them.
Post #585188 Sat Aug 10 2019 10:14pm
HughN
Wales
Even the 'trim removing tools' don't seem to be sharp enough to get under the edges. Melting the centre with a diamond bur in a Dremel seemed to work.
Post #585204 Sun Aug 11 2019 1:43pm
knwatkins
I've removed these with a pair of pincers previously. However, they did snap on the inside. Kev
Post #585212 Sun Aug 11 2019 7:03pm
HughN
Wales
That's how I started, Kev. The possibility of an eternally-rattling door made me think twice. Smile
Post #585227 Mon Aug 12 2019 7:18am
they eventually make their way to the drain holes.
If you carry some needle nose plyers with you, you can get them out when you see them Laughing
Post #585246 Mon Aug 12 2019 11:04am
BiffoBear
Maybe try one of these tools, it's a Sykes Pickavant 045900, I've had it years and it's very robust. 2016 L494 SDV8 AB
2014 Nissan Leaf Tekna
1989 Toyota MR2 MK1b
Post #587320 Sun Sep 22 2019 3:16pm
they aren't any help for them
Post #587324 Sun Sep 22 2019 3:45pm
HughN
Wales
In the end, I melted the core with a Dremel and got the blade of a Swiss army knife under the edge.
Post #587363 Mon Sep 23 2019 6:53am
