![]() | Home > eBay & Bargain Spots > Very very nice color combo 16 plate RRS |
RRS ADDY Member Since: 25 Mar 2019 Location: Lancashire Posts: 18 ![]() ![]() ![]() |
I had a black car once - never again!
Grey was bad enough for me to keep clean ![]() ![]() ![]() * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
It's sort of clean at the moment Rob. At least the outside is as it was in the garage on Tuesday and they jet washed it. Sadly, it cost me £1300 for a pair of new inlet manifolds. An expensive wash! |
Geez! Had they split along a plastic welded seam? Read about that |
One had. As you have to strip a shed load of stuff out to do it, and on the basis that if one has gone the other probably will, I had both changed. The manifold itself is a couple of hundred + VAT. There's £600 + VAT in labour to do the job at a good indy. Apparently LR's book time is 8 hours to do one side only, 12 to do both. Seems a bit excessive, but I'm not in a position to argue. Garage fitted it in at short notice and had two chaps working on it to turn it around ASAP. That's the benefit of a good indy used for several years.
