![]() | Home > Technical > help please - need advice |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
It does sound like battery which you can get tested at Halfords to be sure. They can behave a bit odd when the battery is on its way out, throwing up all manner of electrical gremlins.
wilpert Member Since: 25 Jun 2014 Location: London Village Posts: 169 ![]() ![]() ![]() |
It happened again, I managed to get the car into my local independant dealership (200 mts from my house) and they said it seems like the starter motor.
The current draw from the starter is massive and could draw power from any module trying to power up and do a PBIT, if it can’t complete the BIT it will throw a code. Do you have the drive away handbrake enabled? 2019 5.0 SC SVA (Current)
richardsimkiss Member Since: 13 Feb 2017 Location: Warwickshire Posts: 9 ![]() ![]() ![]() |
FWIW, I recently replaced my battery as on cold mornings I would always get a Hill Descent Control error when starting (and sometimes a 'special programmes off' error as well). The car always turned over fine though. The new battery resolved these errors for me.
Good luck on the 2 hour on a TDV8 if it is the starter you also want the mod breather kit 2008 G4 RRSport TDV8 current
Hmmm...now im getting furthered confused.
It a pipe and y piece that you connect to the starter and put up the side of the bell housing gen L/R part . Water gets into the starter that don’t have them fitted that’s what |
