Home > In Car Electronics > Rear Entertainment Option Vanished! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Is it factory fitted rear entertainment or after market as you may have to reactivate it in the CCF files, although would have thought you would only have to do that if the CD player unit was change as that is generally referred to as the head unit. If aftermarket have you reconnected the video lead to the rear of the screen. Just as a point of interest there is no such thing as a 2007 Autobiography Sport it wasn't introduced until 2010 for the Sport.
Tue Aug 06 2019 6:44am |
The screen is effectively the controller or gateway module. It holds an abridged version of the CCF, if it came out of a car without factory RSE, it will need to be activated to enable the option. There will be more than one edit, possibly up to about 15! 2019 5.0 SC SVA (Current)
Tue Aug 06 2019 6:50am |
Just thinking about this, if your good with a screwdriver you could just swap the screens over. It’s usually only screws and a ribbon cable. That way you keep the original CCF. 2019 5.0 SC SVA (Current)
Tue Aug 06 2019 8:29am |
Feenzz Member Since: 06 Aug 2019 Location: MILTON Keynes Posts: 3 |
Ahhaaa!!! Didn’t know the units were repairable. And (very) annoyingly I’ve binned the old unit. Damn it!!
Tue Aug 06 2019 5:47pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
Very good to know this, thanks |
Tue Aug 06 2019 5:51pm |
