![]() | Home > Technical > mass air flow sensor |
The thing on the air flow box.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 331 ![]() ![]() ![]() |
Thanks for yours Andy!! Researching the problem I am getting it just might just be the Mass-air-flow-sensor that needs a clean. I'v purchased the spray for the job, but before proceeding I am hoping someone out there might be able to send me a picture or better still point me in the direction of a Video as to exactly where the sensor is and how to proceed. Andrew Kennedy |
Well on top of the airbox is a
Many thanks Andy!! Andrew Kennedy |
Andy - after I take out the tube in which the Mass Air Flow Sensor is located, I presume there is no reason why I shouldn't remove the sensor from the tube to clean it??! In fact do I need to take the tube out, cant I simple disconnect the electrics and remove the sensor?!? Andrew Kennedy |
not sure.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
As Andy has already mentioned, when you disconnect the hose(s), you will be able to see the sensor inside the box,,, you will also notice how delicate they are,, basically a thin wire with a resistance in the centre. Last thing you want to do is start poking them, I don't think they tend to get dirty at all so no need to clean, if they are a problem no other option but to replace. 2010 RRS, TDV8
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Cleaning rarely if ever, sorts a problem with the MAF unit.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
As has been said above, cleaning never made any difference to mine either, but a new one sorted it. 13MY Range Rover Sport Autobiography SDV6 - mine
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
10 years ago one of my previous RR was successfully treated with maf cleaner sprayed onto it, so maybe it's one in a million it helps, new is advised if faulty as very sensitive. But of course be sure it's actually faulty before you make it faulty |
