Home > Technical > Dynamic Response System
FuerteRRS
Spain 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi folks, a bit of an odd one but I don't seem to have a dynamic response reservoir on my 2006 RRS HSE. At least not in the place shown in the handbook. I have only had the car for 5 months so am new to this model. The warning lamp is working correctly i.e. when ignition first turned on. Is there a different location for the reservoir.
It is highly unlikely but, the car was returned under warranty for an alarm issue and the mechanic told me there were a lot of faults showing up when he ran diagnostics but he would not tell me what they were. I wonder if there was an expensive problem with the DRS so the removed the reservoir and disabled the system. Bit worrying to say the least. Before I go and look an idiot and tell them to explain I just need to make sure the only location for the reservoir is L side of radiator looking from the front. Is there any way to test the DRS myself. Any advise greatly appreciated.
Dave
Post #584914 Sat Aug 03 2019 3:09pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Hi
Read the handbook/owners manual
Post #584931 Sun Aug 04 2019 12:45am
Should be number three, yellow cap if I remember right, were all cars fitted with it?
Post #584934 Sun Aug 04 2019 3:50am
Brit Plumber
I would also question whether the car had DRS fitted. There’s a lot of work involved in removing it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584939 Sun Aug 04 2019 8:59am
