Home > Wheels & Tyres > Grabbed A/T 3’s
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Grabbed A/T 3’s
Just had my grabbers fitted this morning, went for 45 profile think they look ok!
 Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #584857 Fri Aug 02 2019 10:22am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
They look good! Cool I'll be interested on how you find the wet weather handling as I am looking at fitting the 275/45/20 V to mine this winter There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #584861 Fri Aug 02 2019 11:43am
Stu
I have used these tyres for years now in all incarnations from the original A/T’s up to the current version. I have never had a problem with them in any conditions. If you drive according to the weather and your abilities you’ll be fine. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #584863 Fri Aug 02 2019 11:59am
I found the 255/55/19 got a little bit slippy in the wet as they wore down below half tread depth. It was only if I was a bit aggressive with them, to be honest, but a hard brake would get the ABS cutting in where when new it didn't, strangely.
They still worked well off road when worn, by the way. 2012 SDV6 - it's missing a couple of cylinders
Post #584864 Fri Aug 02 2019 12:04pm
