![]() | Home > General (L494) > JLR Letter on Oil Dilution |
You can use an IID to monitor certain Live Values that are indicators of regenerations
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Yes, but why should we have to pull out our IID tool?
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 27 ![]() ![]() |
“Average of 40 mph for 20 minutes? Can’t see that would produce any temperature in the filter, 42 mph is 1200 rpm in top gear on my SDV6, better to quote an RPM, saw a regen on a Vauxhall done stationary at 3000rpm to get the dpf to 6000c for a good half hour. Saying that, have had no problems with mine, live 2miles from a dual carriageway and plenty of hills! Never noticed regening. |
BoldlyGo Member Since: 13 Jan 2006 Location: Surrey Posts: 216 ![]() ![]() |
Hi there
IIRC the 2015MY owners manual stated that a regen should be made at high revs / low gear at 40mph or above for at least 20 minutes........... that means putting the gearbox into manual mode to do it, preventing an upshift. There was a similar paragraph in my 2014MY Evoque’s manual as well. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
That's interesting, on my EU5 2012 dpf sdv6 usually 20 to 30 mins dual carriageway in D mode standard sorts it. |
Ive had my (Exhaust filter nearly full) message come on a few times & ive driven it on back roads in sport mode using the gears manually at around 4000 rpm & within about 10 miles the light goes out.Ive also had my snap-on diagnostics on to do a regen & within a mile or so it comes up with soot within limits. Andy.
