Home > Technical > Restricted Performance issues MY2012 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Smoke test is required to determine any boost leaks |
Sat Jul 20 2019 6:26pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
I got this gremlin already for a couple of years. Code 1247.00. NO Leaks (smoke test was performed by JLR dealer) no other DTC's. After turning it of for 3 minutes, the car drives strong , particularly on the highway, after turn of the ignition, Until next event, when it appears again usually after a could start. It does not seem a serious problem, but it is annoying.
Sat Jul 20 2019 9:44pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 202 |
Back from the dealer an oring was replaced somewhere and after 160miles today pulls like a train (so far)..... 2018 Telsa MS
Sat Jul 27 2019 2:41pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
I get a restricted performance warning about every week or two (sticking turbo actuators I believe) on my TDV8. When I clean the intake system it goes for a few weeks longer between warnings.
Mon Jul 29 2019 12:59pm |
And back to the dealer this morning. While driving a short distance yesterday I dropped it into Sport mode, a short 10 minutes later the warning light came on. This morning I did the same, started off in Sport and 10 minutes later the warning light appeared. 2018 Telsa MS
Mon Jul 29 2019 2:21pm |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
I don’t know what engine you have in your car, but on the TDV8’s both 3.6 and 4.4 the inlet manifolds split and the rubber stub pipes that join them split too. Also the inter cooler hoses can let go. All of the above can cause restricted performance errors. Current: 2010 RRS 3.6 TDV8 HSE
Mon Jul 29 2019 7:28pm |
Quote:
Tue Jul 30 2019 8:57am |
It's a SDV6 3.0, all quiet from the dealer so for... 2018 Telsa MS
Tue Jul 30 2019 10:33am |
Sorry can’t help any further as I have no experience of the V6 engines. Good luck anyway and I am interested to see how you get on. Current: 2010 RRS 3.6 TDV8 HSE
Tue Jul 30 2019 11:10am |
The car has been back and forth to the dealer for the same problem over the last 6 weeks. Last week I could smell exhaust in the cabin while at a stop light. Sure enough today they looked and found an exhaust leak at the rear of the engine, it's been in and out of the shop 5 times since the start! More to come. 2018 Telsa MS
Mon Aug 12 2019 2:26pm |
Success! The cross over pipe was split along with a melted fuel pipe. The Land Rover extended warranty finally put to good use! 2018 Telsa MS
Tue Aug 13 2019 12:53pm |
That cross over pipe appears to be a common failing point on the SDV6, there was a chap on the forum last year with the same issue but he was told the LR warranty wouldn’t cover it. He was battling them as in everyone’s opinion it quite rightly should be covered. 2019 5.0 SC SVA (Current)
Tue Aug 13 2019 2:51pm |
What is not a common issue, when it comes to “ristricted performance” ?
Tue Aug 13 2019 3:22pm |
While I'm out of the country the car has been mended and they even threw in a set of front discs. Had a bit of the steering wobble, they had been replaced last year by the dealer. 2 year warranty on the discs! 2018 Telsa MS
Tue Aug 20 2019 6:31pm |
