Home > Maintenance & Modifications > drivers seat adjustable arm rest broken mechanism
CW5
Hi All, where the adjustable arm pivots in the drivers seat - it is broken. The physical plastics have cracked and need replacing. Is there a kit for this ? has any one suffered the same breakage? The arm rest will not hold position now as the plastic internals are mashed ( technical term). appreciate input. Thanks in advance. Carl
Post #584090 Wed Jul 17 2019 9:31am
Brit Plumber
Is the broken part, part of the seat or arm rest? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584111 Wed Jul 17 2019 5:44pm
