![]() | Home > Technical > Upper tailgate release |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
How can you get the switch without getting the panel? 91 BMW 850CSI |
Took it apart today.
Boater-Al Member Since: 09 Oct 2012 Location: Maidenhead Posts: 13 ![]() ![]() ![]() |
Sender Member Since: 14 Mar 2014 Location: Jersey Posts: 24 ![]() ![]() ![]() |
Hi new here and didn't want to start a new thread for a common issue but wanted to see if you think its the switch or the lock from my diagnoses.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
£25 for a genuine LR switch,I replaced mine last week.Easy to test if your switch doesn't fall apart when you take it out |
stevietee10 Member Since: 07 Jul 2010 Location: Nuneaton Posts: 10 ![]() ![]() ![]() |
Hi Guys
grey17 Member Since: 18 Jul 2016 Location: Devon Posts: 63 ![]() ![]() ![]() |
Despite reading and studying this entire thread, the top tailgate release switch will NOT come out no matter how many people say it will just pop out!
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 ![]() ![]() ![]() |
put the sctewdriver in the gap, and use it to push the switch across, (against a spring if you like) and then help it out.
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
Same problem with my 2008 RRS
MhairiC Member Since: 22 Jan 2022 Location: West Lothian Posts: 4 ![]() ![]() ![]() |
I’ve had the same problem and through this thread was able to fix. Great advice on how to get the switch out. Was able to see the small red button which worked when pressed so knew it was just corrosion on the metal plate etc which I was able to clean up and put back together with some blue tac for good measure which also might help keep the water at bay. Thank you everyone- this thread saved me money and time. |
