Home > For Sale & Wanted > [For Sale] Instrument cluster
DerrekL
I have an instrument cluster that has a fault that triggers the doors to lock etc; this is a known issue and I believe the instrument cluster can indeed be fixed. Although I took the route of buying a new one. So I'm obviously selling this as faulty only useful to someone who knows what to do with it to get it working.
This was taken from my RRS 2007 HSE RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #583872 Fri Jul 12 2019 11:40am
Brit Plumber
Is sounds like drive away locking was switched on rather than a fault. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583906 Sat Jul 13 2019 7:28am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Tend to agree with Brit, on my 2012 you can enabe and disable it through the menu system per handbook.
Post #583914 Sat Jul 13 2019 9:46am
Disco_Mikey
Unless it had a CAN fault, which would also cause the doors to lock, hazards to flash and so on
In which case, a new IPC would not have fixed it, and the OP would still ha e the same issue Thumbs Up
Post #583924 Sat Jul 13 2019 11:35am
DerrekL
Yes Mikey that's the correct answer Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #583950 Sat Jul 13 2019 8:44pm
