![]() | Home > Technical > Parking Sensor - control box |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 ![]() ![]() ![]() |
It is on the left side.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 328 ![]() ![]() ![]() |
Thanks Andy for your thoughts!! It's only the rear sensors that are a problem......Its 50/50 they either stay on permanently when in reverse or they behave themselves - any thoughts as to what I should be looking for out of your suggestions. Advice gratefully received. Andrew Andrew Kennedy |
Something likely to knock out a PDC sensor on earlier RRS is using a pressure washer on then, can force water into a sensor and cause it to fail as can Road salt in the winter! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
1 rear sensor is faulty then.
Thanks for the advice. So I will buy a couple of sensors for the rear and make the changes to see if I can find the one/s that are not working and hopefully that will solve the problem. Can you advice me exactly how I proceed to get at the rear sensors? and hopefully something I will be able to do?!? Andrew Kennedy |
Remove rear left light if you wish to disconnect the loom.
Barclay Member Since: 11 Sep 2018 Location: Aberdeen Posts: 4 ![]() ![]() |
Hello Andrew, this reminds me of an issue I had with my old 2006 RRS.
