Home > Technical > Auto setting for suspension to low on igition off? |
TonyS Member Since: 07 Jul 2019 Location: Perth Posts: 2 |
Does anyone know if there is a setting so that the suspension automatically drops to the low setting on turning off the ignition?
Sun Jul 07 2019 2:49am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
On a RRS1 I'm afraid there isn't.
Sun Jul 07 2019 4:41am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
As indicated not available. However in the earlier RRS the Land Rover Button on the key fob can be programmed to raise and lower the suspension and this option may meet your needs if the same is available on your later model.
Sun Jul 07 2019 8:36am |
Yes it is the same on the facelift variants.
Sun Jul 07 2019 8:55am |
As Andy says above. Or just select it at stop. |
Sun Jul 07 2019 11:45am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
I believe it is perceived wisdom on here that the car should always be moving or moved with/after a new suspension height is reached so as to relieve any strain on suspension bits due to changes in geometry of the new height. I always select Access height just before parking up so that it has a chance to settle in the new geometry whilst I am still moving. Or if I stop before it has reached the new height then just a quick slot into forward and then reverse will do the trick. I might be being a shade too precious here but it’s no great hardship to make it part of your parking routine. Robin
Sun Jul 07 2019 3:25pm |
"I believe it is perceived wisdom on here that the car should always be moving or moved with/after a new suspension height is reached so as to relieve any strain on suspension bits due to changes in geometry of the new height."
Sun Jul 07 2019 6:21pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
best done when the park brake is off
Sun Jul 07 2019 8:40pm |
Why ? |
Sun Jul 07 2019 8:41pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
When the suspension goes up and down with the handbrake on (or in Park) I'd guess there is a certain amount of 'rotation' of the wheel vs the hub due to the geometry of the suspension arms (IIRC it's semi trailing arm both ends?) - with the brakes on, that rotation is working against the brakes and you are effectively 'loading up' the torsional stress into all of the components that want to move but can't..
Mon Jul 08 2019 8:18am |
exactly that |
Mon Jul 08 2019 11:06am |
Interesting point and thanks for the explanation. One would hope these components were not so delicate to fail as a result. |
Mon Jul 08 2019 11:29am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
indeed, you really shouldn't be lowering/raising the car when standing still on a firm surface.
Mon Jul 08 2019 11:41am |
I understand the argument but then you would think JLR would say this in the manual (they don't in my 2012my uk version). In fact it explicitly tells you how to put it in access mode up to 40 secs after ignition is off (don't open driver door). They could also have interlocked it so you had to be on the move to select or change heights.
Mon Jul 08 2019 5:52pm |
