Home > In Car Electronics > Drivers seat cushion stuck in the highest.
Badger86
Car is 2011. Drivers side seat cushion
Cushion should move up and down. Passenger does. When you push the button the seat module underneath the seat just clicks. Every other function works except this one.
I assume its the seat module that's gone and does it need recoding to the car before I buy another?
Post #583624 Sat Jul 06 2019 3:56pm
Brit Plumber
Before you go down that route, remove the cushion (4 Torx screws) and check all connections and wire condition. I have (not on my current car) had an actuator go into a geometric lock on a regular basis. If I sat in it to adjust, it would lock in the most upper position. To unlock it I’d get out and operate the switch from outside the vehicle. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583740 Tue Jul 09 2019 7:37am
