![]() | Home > Faults & Fixes > Raod speed noise can not diagnose? Not prop center bearing |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
the only thing i can stab a guess at is an old door seal? hence why you don't hear it once a window is open......
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 ![]() ![]() ![]() |
Hey Wangie,
Check your tyres for feathering,,run your hand round the edge of the tyre inner & outer & if it is going up & down on the tread that is the problem,,ive had loads of folk come in to my place saying they have a wheel bearing gone & its been a tyre,usually on the rear. Andy.
+1^^^
Well, I seem to have three out of four tyres that have varying degrees of feathering (very light on one rear, middling on both fronts) on the outside edge. So that might indicate a misalignment which annoys me somewhat...
