Home > General > suspension question......
Eskimo
Right folks, I have a quick question regarding the suspension on my 2006 RRS.
Last weekend I ended up having to swap out my compressor, I'd tried a rebuild kit from X8R which worked for a few days but then the fault came back again. I bought an exhaust and air delivery valve kit too. When trying to undo the air delivery valve it sheared off so a new compressor was needed.
New Dunlop compressor from MM4x4 fitted and fault has gone away, and she is up and down with no issues. However every so often now when either closing a door or locking/unlocking the car there is a sudden loud(ish) whoosh, for want of a better word.
There are no errors or codes shown when read with a friends reader, the car seems to perform perfectly so the question is is there something wrong or as it is now the warmest time of year that I've owned the RRS for is this a normal process to avoid over pressuring as the air expands in the system.
it doesn't happen every time, and sometimes it has been after a very short journey and sometimes it does it after a longer one. Any help, suggestions would be greatly received.
many thanks 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #583290 Sat Jun 29 2019 10:54pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
normal, self levelling
Post #583291 Sat Jun 29 2019 10:59pm
Stevepd
Normal. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #583294 Sun Jun 30 2019 5:51am
Macca
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Def normal, should notice the back end gently drop D3 TDV6 SE auto 2006
FFRR TD6 vogue SE Overfinch 2006
RRS TDV6 HSE 2007
L322 4.4 TDV8 Overfinch 2012
Post #583297 Sun Jun 30 2019 7:53am
Eskimo
Thanks guys , figured it might be normal but as only just started after new compressor was fitted was getting a little concerned that there was a secondary issue, especially as it was loud enough for a colleague to hear in the car park about 30ft away Laughing Laughing
Can go back to enjoying it again now and wait for the next issue to rear its head Whistle Whistle 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
Post #583307 Sun Jun 30 2019 12:31pm
garrycol
Australia
You didn't need to buy a new compressor - you could have drilled out the sheared exhaust valve and put the new one in.
With the noise on the new compressor - did you reconnect the exhaust line that has the muffler in it? If this has not been reconnected the exhaust vents straight to atmosphere and not through the muffler so making a much louder noise.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #583309 Sun Jun 30 2019 2:17pm
Eskimo
Garry, sadly as I needed the RRS quickly and the repair kit I got only had the internal spring and rubber bit I was up the proverbial without the necessary paddle Big Cry Big Cry Rolling with laughter Rolling with laughter Rolling with laughter
So the only quick fix solution was the new compressor, that said I might well now try and fully rebuild the old one ready for when this one fails.
I believe all pipes were refitted,but will have a quick look this week and make sure all are connected and tight, my guess would be that the exhaust one has come loose since fitting fingers crossed. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
Post #583333 Sun Jun 30 2019 8:49pm
garrycol
Australia
My exhaust valve also snapped off but in doing so the crud that was stopping the valve from closing dislodged so it started working even though the hex head was broken off. I have a new valve and hex housing ready to go if the compressor plays up in the future.
The rest of my compressor rebuild went well but I did need the metal desiccant container cap. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #583347 Mon Jul 01 2019 2:49am
Eskimo
Garry, just to let you know that yes the the exhaust pipe was loose from the compressor, guessing i hand't pushed it fully home, and then knocked it off when fitting the cover.
Now pushed fully home and no noise from it Laughing Laughing 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
Post #583520 Thu Jul 04 2019 1:38pm
