![]() | Home > Maintenance & Modifications > what is locking my rear wheel |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
Inside the hub are the park brake shoes. So that's prob the cause.
tony waterman Member Since: 23 Jun 2019 Location: benwick march cambs Posts: 13 ![]() ![]() |
HI Andy, thanks i have just watched the video now i know what i am doing i will have a go tomorrow at freeing the drum. thanks again for your help. |
you may also find this post helpful.
May be worth doing a strip and clean or you may find the park brake seizing on again. 2019 5.0 SC SVA (Current)
yes if i ever get the engine running i plan to renew the lot. so i finally managed to free the drum, i took the caliper off took out the drum retaining bolt so the whole thing was loose sprayed through the drum adjusting hole with wd40 left it for 30 mins then whacked 7 bells out of it with a rubber mallet and 10 mins later a free spinning hub.
