Home > General > Compressor leak
Titch
United Kingdom 2007 Range Rover Sport TDV6 HSE Lucerne Green
Compressor leak
Hi all
After having a suspension light pop up on the dash i read the codes and it came up as C1A20, so felt some investigation was needed.
On looking at the pump I have discovered the air is leaking out of the pump where the push in pipes go, the red and blue ones.
So my question is are any of the repair kits anygood?
Has anyone used one successfully?
I am looking at the one pictured
Post #582905 Sun Jun 23 2019 5:09pm
Yeah the repair kits are good
Post #582907 Sun Jun 23 2019 5:40pm
Titch
Better order one then
Post #582909 Sun Jun 23 2019 6:24pm
Bardley
Just fitted that kit on my Hitachi as preventative measure.
New silica and filters, and alu end cap.
Easy enough to take the air dryer off leaving compressor on the car.
Have a read here:
https://www.disco4.com/forum/post2009169.html#2009169 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #582917 Sun Jun 23 2019 9:41pm
garrycol
Australia
That kit does not have the piston "ring" and glide - you will need that as well. Also consider the replacing the exhaust valve and housing.
I dont know why these kits do not include everything with the option of buying just the bits you need.
I rebuilt mine a couple of months back and it still leaked internally which was the exhaust valve sticking open - fixed that and the pump is now all good - no codes.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #582921 Mon Jun 24 2019 12:27am
Titch
Have a read here:
Fantastic thread thanks so much it is very simple to do it that way and half the hassle.
Post #584201 Sat Jul 20 2019 3:11pm
