![]() | Home > Detailing & Car Cleaning > Snow foam lance prob |
Have you stripped it down & given it a good clean,also it could be the filter gauze that is blocked.Might be worth buying a new gauze first as they are cheap enough.what I do with mine every time I finish using it I unscrew the bottle with foam in it & put the pipe in a container with clean water & run that through the gun to keep the gauze clean. Andy.
I haven’t.
Depends which lance you have. Andy.
If it’s like this then here you are
Thanks. I’ll check that video |
& their is this one Andy,this is the lance I have
Thanks guys |
The tiny hole that the soap goes thru was blocked.
