![]() | Home > General > water leaking in to passenger side floor |
Loads of help available on here, however a little basic info might help, for example:-
Do you have a sunroof? |
ashleighash Member Since: 13 Apr 2018 Location: fulham Posts: 25 ![]() ![]() ![]() |
yes but not leaking from there |
Are the sunroof drain tubes clear |
I think, the drain tubes run down the a posts and exit behind the side vents. you can always remove the side vent and pour some water down the into the drain tube area of the sun roof, measured amount in should equal the measured amount out.
In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Had my A pillar off last week and I have these drain tubes....and I don’t have a sunroof lol. 2019 5.0 SC SVA (Current)
