Home > In Car Electronics > land rover logo only after incartec kit installed
Spain 2006 Range Rover Sport TDV6 HSE Santorini Black
This is an old problem I have only just had time to address. Full incartec kit purchased when replacing existing stereo with Pioneer head unit. Everything up and running fine using RobK guide in this forum except for the Satnav dash, which just shows the Land Rover Logo. Checked the Fibre optic cable and can see red light at both ends so is not the cable. Checked IIDTool to see if any errors and shows fine so have send incartec an email but as being Saturday I dont expect a reply until Monday so was wondering if anything else i can check before then. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
RRS 2008 3.6 V8 SILVER/GREY (WIFES XMAS PRESENT)
Post #582445 Sat Jun 15 2019 9:00am
the LR logo means it can't communicate with anything. It has only powered up.
if you look into the orange fibre connector. you should see a red light on both orange cables, as one is transmit and one receive.
Post #582449 Sat Jun 15 2019 9:53am
03184
Hi Andy yes I see 1 red light from nav screen end and other red light coming from old head unit that was disassembled. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #582452 Sat Jun 15 2019 10:23am
03184
just an update to this, IIDTool is showing some errors, the first im assuming is that i have removed the antenna cable from the loom. The second error Im wondering if could be the cause ????
Post #582458 Sat Jun 15 2019 12:22pm
SRE
Spain
Can I ask, is the IIDtool is compatible with your new incartec kit Question In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #582459 Sat Jun 15 2019 12:43pm
03184
thats a good question that I have no idea how to answer lol. How would I find that out ?
On a side note and i'm probably wrong as Im not a sparky, I thought if i bypassed all the incartec loom and just connect the old disassembled head unit back up, in theory the satnav screen should kick back in ???? Did this and was still stuck on LR logo. Photos below
Post #582460 Sat Jun 15 2019 12:45pm
Pufftmw
IID Tool would not be "compatible"
These are what I currently have after I have fitted the InCarTec kit & a HU
Audio Amplifier
B1A06-13 (2F) Speaker 6 circuit - General electrical failure - circuit open
( on 27-02-2018 00:31:09 at 243266 km )
B1A05-13 (2F) Speaker 5 circuit - General electrical failure - circuit open
B1A03-13 (2F) Speaker 3 circuit - General electrical failure - circuit open
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
B1A04-13 (2F) Speaker 4 circuit - General electrical failure - circuit open
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
B1A96-68 (2C) Bus still active after shutdown request - Algorithm based failure - event information
Audio System
B1A56-01 (2B) Antenna circuit - General failure information - general electrical failure
( on 25-03-2018 14:51:09 at 245302 km )
These faults repeat on a regular basis, Amp shown as you probably will have those as well. So yes, your second may be the cause. On InCarTec's site, there should be good instructions about tearing down the original HU to keep only the bit needed for the 4x4 info and SatNav, maybe worth revisiting that just to check you haven't missed or added a step.
Post #582466 Sat Jun 15 2019 1:47pm
03184
good idea. I havent actually ever seen those errors you have aside from the antenna. The head unit was put in about a year ago and works fine apart from the satnav screen. From my recollection the incartec kit only came with basic instructions regarding the actual installation but yes it did come with the old HU teardown which I did. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #582468 Sat Jun 15 2019 1:51pm
SRE
Spain
[quote="03184"]thats a good question that I have no idea how to answer lol. How would I find that out ?
A quick email to Pat at GAP. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #582478 Sat Jun 15 2019 3:36pm
Antenna circuit fault code is fairly normal. Probably unrelated.
Post #582480 Sat Jun 15 2019 3:59pm
03184
searching about for the other fault without much success atm RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #582484 Sat Jun 15 2019 5:12pm
Steering wheel controls maybe?
Post #582486 Sat Jun 15 2019 5:22pm
03184
i did note that one of the pins from the SWC had come out and have put back in and steering wheel controls work, will rescan for faults. Just to check now where the link is dying for the satnav RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Post #582490 Sat Jun 15 2019 5:47pm
03184
update, so didnt realise there was a diagnostic menu that i found on a different forum. Accessing this brings up the sat navigation which works fine. Reading up on what can be tested from the menu to see if it sheds any light. The only thing i found so far was in the MOST test that it shows status zero power.
Post #582500 Sat Jun 15 2019 10:51pm
I can't help think you have done something wrong when taking the radio apart.
It is the only thing different now? to when it was working.
Post #582522 Sun Jun 16 2019 8:40am
