Home > Tips & Tricks > Wheel arch fix
Dmcookie
Wheel arch fix
Some lovely individual has hit the side of my car and the panel that starts over the wheel arch has popped out. I’m thinking that I need some type of metal clip to try and put it back in place?
Any ideas?
Post #581371 Sun May 26 2019 1:35pm
Brit Plumber
You’ve not said what model. I’m assuming it’s the black trim at the front of the rear wheel arch on an L320? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582214 Tue Jun 11 2019 6:48pm
Dmcookie
Hi.
Yes, that’s the model.
Post #582246 Wed Jun 12 2019 11:09am
Brit Plumber
Ok, it’s a plastic clip affair. One part on the trim and the other in the body. They then clip together. I’d get some original clips as the eBay ones break when you try and clip them together.
I’ll try and get the pt no tonight. 2019 5.0 SC SVA (Current)
Post #582248 Wed Jun 12 2019 11:39am
Dmcookie
That would be great.
Thank you.
Post #582249 Wed Jun 12 2019 11:43am
Brit Plumber
PART NO: DYC101420
Eng. PN UH121861BBA
Lots on ebay but I found the ones I got from ebay were to brittle and snapped when I fitted the trim. If you only need one or two it may be worth buying from your local LR dealer. 2019 5.0 SC SVA (Current)
Post #582280 Wed Jun 12 2019 7:35pm
Dmcookie
That’s great.
Thanks very much for your help.
Post #582300 Thu Jun 13 2019 5:58am
