Home > In Car Electronics > HK Audio in 2010 facelift HSE
MrGimper
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi all
Alas a week ago my beloved 2005 HSE was rear-ended and has been written off Sad
I’m now looking at a 2009/10 facelift to replace her
One thing that I was never happy with was the HK audio. Is the HK audio in the 2010 facelift version just as bad?
Is there a logic 7 upgrade because every car I’ve viewed online just states HK
Post #582282 Wed Jun 12 2019 9:33pm
The Logic 7 was only standard factory fitment on the A/B's it was a factory option on other models. So would depend on if ordered when vehicle new.
Post #582285 Wed Jun 12 2019 10:30pm
Brit Plumber
It’s possible to upgrade to Logic 7 with the purchase of a Premium Amp and additional speakers (depending on what you’re upgrading from).
I like the Logic 7 and it sounds much better than my wife’s 1 year old Focus. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582286 Wed Jun 12 2019 10:43pm
MrGimper
Thanks. Most adverts show the Harmon Kardon logo on the speakers. Would this also say Logic 7 underneath if it was a Logic 7 system? I’m trying to determine if vehicles have it before I actually go see them.
Post #582287 Wed Jun 12 2019 10:50pm
Brit Plumber
Yes it does, but only use it as a guide and check when you view the car by checking the settings on the screen. 2019 5.0 SC SVA (Current)
Post #582289 Wed Jun 12 2019 11:18pm
Mine has this, have a quick look at rear of headlining should also have a couple of speakers there if logic 7 but someone could always have added them though.
Post #582290 Wed Jun 12 2019 11:23pm
MrGimper
Grrrrrr so most I’ve seen don’t have it from the pics of the speaker grills
Post #582291 Wed Jun 12 2019 11:33pm
ilard
You get Logic 7 with the HSE Luxury pack... a pack that is well worth having if not getting an AB.
If I remember it included:
Logic 7
Sunroof
Wheels upgrade
Adaptive cruise
Extended leather (with contrast stitching if applicable to colour way)
Maybe one or two other bits. Heated steering, probably?
I don’t think the hifi is amazeballs, it’s ok, depends what you’re used to, so I’m rather glad I’m not stuck with the standard sound system. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #582293 Thu Jun 13 2019 5:47am
OP was looking at 2009/10 facelift, not sure the HSE Lux existed then or when it was introduced though.
Post #582298 Thu Jun 13 2019 6:20am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I have a HK Logic 7 system installed in my 2010 TDV8 and to be quite frank its really average in sound quality. I don't understand why they call it a premium quality system. I don't know how bad the normal system is, maybe it really bad.
Post #582653 Wed Jun 19 2019 12:46pm
Brit Plumber
I rate mine, the source plays a big part in quality. If I play back from a USB it’s ok but playback from a CD or DAB is crystal clear. The Sub isn’t the best but that’s more to do with Land Rover build rather than the HK system. 2019 5.0 SC SVA (Current)
Post #582654 Wed Jun 19 2019 12:58pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Brit plumber is right. Source matters. Lossy mp3s at low bitrate sound crap anywhere and on any system. Cd quality ripped to a hard drive or usb stick as a minimum, no excuses as it is easy to do and storage is cheap.
The standard hk system is ok with a good source (eg hi res or mqa stream from tidal via bluetooth or in via aux input) though, but could have done with a more powerful amp section. The rattly tailgate sub is an easy low cost fix, I put a post in tips and tricks explaining that.
Post #582698 Wed Jun 19 2019 10:27pm
