Home > Wheels & Tyres > New 22” SVR Viper gloss black alloys fitted.
MBRRS
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Java Black
had these fitted Very Happy
 The name’s Bond ‘ James Bond’
Post #582055 Sun Jun 09 2019 5:51am
Tyrefitter
Looks really nice with those wheels Thumbs Up Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #582063 Sun Jun 09 2019 7:01am
MBRRS
Cheers Andy. Got them for £2.5k with conti sport tyres Brand new gives it a real stance look The name’s Bond ‘ James Bond’
Post #582065 Sun Jun 09 2019 7:07am
Tyrefitter
Good price that,the tyres alone are near on £300 each if they are the 295/40r22’s which I’m guessing they are,same tyres I’ve got fitted on mine.The only problem I have with the conti’s is they are very noisy,I don’t think I’ll be fitting them again when they wear out,I’m probably going to try the Goodyear Eagle F1’s.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #582066 Sun Jun 09 2019 7:16am
MBRRS
Yeah they are 295/40/22 straight from the dealership!!! The name’s Bond ‘ James Bond’
Post #582067 Sun Jun 09 2019 7:17am
Tyrefitter
Another thing you could consider is fitting 30mm spacers on the rear it does finish it off nice.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #582068 Sun Jun 09 2019 7:18am
MBRRS
Will that bring them out then. They are wider then my original 22” as they were fitted with 275 I might get the SVR wheel arch extensions. Whistle The name’s Bond ‘ James Bond’
Post #582070 Sun Jun 09 2019 7:20am
Tyrefitter
I’m sure the svr could be 10”wide & mine are 9.5” wide but then again my off set is 45,I don’t know what the off set on the svr wheels is.you could always try the spacers & if they stick out more than the arches you could fit the arch trim,here’s a few pics of my Old SC with the same wheels & spacers.Ive got to admit the all black look looks really nice,it’s just keeping it looking clean is the problem.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #582071 Sun Jun 09 2019 7:30am
Jjvd21
United States
SVR 22x10 wheels have a 42.5 offset according to LR.
Post #582099 Sun Jun 09 2019 1:21pm
Tyrefitter
So they would need the arch extensions as mine are 9.5 & 45 offset so the svr alloys would stick out 10mm more than mine,unless you got 20mm spacers then you wouldn’t need the arch extensions. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #582101 Sun Jun 09 2019 1:40pm
Terras14
The svr rim is 22x10 with offset 42.5. Which means it is 0.5 wider and with a lower offset, it will stick out more.
So if you add spacer, it will stick out even more.
Nothing against spacer but getting a rim with good offset to get that flushed look is better than spacer since rrs is such a heavy car.
I just order this rim also but I am fitting 285/40/R22 tyre.
Post #588810 Fri Oct 18 2019 4:39am
