Home > General > Starter motor cuts out after 1 second when car is cold |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Very symptomatic of a weak battery. I'd suggest have it tested for output |
Sun Jan 06 2019 7:18pm |
PompeyDave Member Since: 08 Jul 2018 Location: Portsmouth Posts: 64 |
Ok, sounds like good advice. I’ll get it checked. |
Sun Jan 06 2019 7:34pm |
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 |
I’m having the same problem , maybe 2 or 3 times a week this happens but hot or cold , no real pattern , did you find the problem, battery turns engine over fine on second or 3rd attempt, my car is a 2010 3.6 also , any ideas ? |
Thu Jun 06 2019 6:35pm |
Sorry, should have updated this one. It was indeed a dying battery. Once a new one was fitted it spun up far quicker than under the old battery so it was clearly on its way out. Problem solved and no further cut outs on starting. Best deal I could find on the correct battery with a 5 year guarantee was this one from Yuasa at £106 posted:
Thu Jun 06 2019 6:44pm |
Thank , I will get one tomorrow |
Thu Jun 06 2019 6:47pm |
