![]() | Home > General > TDV8 down on power, its a long one |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9037 ![]() ![]() ![]() |
I'm going to guess that one or both turbos has failed. Lots of white smoke is what mine did when the turbos went. 2012 SDV6 - it's missing a couple of cylinders
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 ![]() ![]() ![]() |
Sorry I forgot to add that after the white smoke cleared the car drove flawlessly from Garage A to Garage B bar the misfire. Garage A blamed the smoke on injector cleaner. Now the car isn't smoking at all it is running very smooth but low on power. |
If all of your 8 injectors are out of spec, I'd definitely get them replaced. Out of spec injectors could cause an imbalance in the engine which could cause catastrophic damage at some point.
No the turbos were changed about 5 years ago. I'm struggling to think of an original part on my illustrious machine |
Searching36tdv8 Member Since: 06 Jan 2018 Location: Milano Posts: 6 ![]() ![]() |
I had the same problem, but without loss of power.
Thanks for the input guys, got the car back yesterday and its running better than ever.
Glad you got it sorted |
Can you recover the cost of 2 Friday injectors?
I'm hoping I can recover the cost of the previous 2 injectors yes.
The plot thickens. I drive the car to Portugal every year as I live here for 6 months of the year. The car was driving fine, I got to near Salamanca in Spain so 1200 miles from my house and I filled the car up. As I set off to join the motorway again the car wouldn't accelerate up the hill, then all of a sudden it went. After a few minutes of driving the overheat light came on so I pulled over. Steam was coming from the bonnet area so I opened it and steam went absolutely everywhere!
