Home > Faults & Fixes > Christmas Trees....
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Christmas Trees....
Good Afternoon All,
So I got the infamous Christmas lights in the car today.
Basically, 1hr drive in 40C heat with a 20 minute stop with engine left running. No issues
After returning to the car 3 hours later it wouldn't start, and all the lights lit up.
I cleared all faults using the IDD Tool and the car finally started, but it struggled (so assumed the battery had drained) took the car for a drive (20 mins) to top up the battery and no issues. Only had the park brake light fault remained.
Stopped, cleared faults again and everything was gone. I did however note that a couple of times the IDD Tool did say "unable to update".
Returned to car an hour later and Christmas tree back, including hazards on, and various warning about HDC, transmission faults, suspension etc etc. Tried clearing faults with no great success, but eventually got her started and limped home (2 mins drive)
Basically, had no 1st or 2nd, and steering very heavy, temperature gauge through the roof with warning light on, however voltage from IDD tool showed 14.4 when engine running and AC etc on.
At home I disconnected the battery and checked , only 10V max. Shorted the cables to do a hard reset reconnected and tried to start, all lights back and nothing. No real surprise if the battery is at 10V...
So question is, is it:
A. Brake switch by pedals, or
B. Dead Battery, or
C. Dead alternator, or
D. None of the above.
Would appreciate any feedback as its now the weekend here, as well as Ramadan so hoping it's the battery so I can sort it myself tonight. If not the cars off the road 'til Sunday and will need to be towed as I'm not risking further damage by driving in her in this condition.
THanks in advance
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #581603 Thu May 30 2019 2:26pm
gogsy1956
I would think the battery would be your first option,,, 14V plus showing at tickover sounds like a healthy alternator,,, 10V at battery looks as if it has completely failed on a few cells. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #581606 Thu May 30 2019 2:35pm
Spangler
Had a very similar experience recently to what you are saying you're having. Mine required a new instrument cluster however I would definitely try a replacement battery as a starting point.
Post #581620 Thu May 30 2019 4:18pm
Guyzer73
Gogsy, Spangler,
Spot on battery was FUBAR...Just wasn't sure as it's less than 18 months old but it does get loads of abuse with lots of short journeys and extremely hot weather. We've had northward of 40C last few days so I guess it all takes its toll.
Swapped m new battery from Bosch, cleared faults and all good. Let's see tomorrow morning how things look.
Thanks again 2006 RRS S/C CONSTANTLY under modification...
Post #581622 Thu May 30 2019 4:29pm
Spangler
Good to hear it looks to have been resolved quickly and cheaply. Fingers crossed you have no more issues.
Post #581623 Thu May 30 2019 4:32pm
Guyzer73
Spangler,
It's a 13 year old Land Rover, of course there will be issues 😁😁
Cheers Thumbs Up 2006 RRS S/C CONSTANTLY under modification...
Post #581625 Thu May 30 2019 4:41pm
knwatkins
Glad you got it sorted Guyzer Thumbs Up Kev
Post #581628 Thu May 30 2019 5:25pm
gogsy1956
Failed after 18 months,,, I know there is an optimum working temperature but I would have thought it should last a bit longer, a lot of manufacturers offer 3 or 4 guarantees now,, even with the cheaper units. 2010 RRS, TDV8
22" overfinch
Post #581632 Thu May 30 2019 5:44pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
gogsy1956 wrote:
Failed after 18 months,,, I know there is an optimum working temperature but I would have thought it should last a bit longer, a lot of manufacturers offer 3 or 4 guarantees now,, even with the cheaper units.:
I'm not surprised at all with those temperatures. While cold weather takes it's toll on the output of a battery, hot temperatures kills them sooner.
Edit - after posting the above I thought I'd do a quick google for info to back that up, and below is a copy/paste of a google headline
The optimum operating temperature for the lead-acid battery is 25°C (77°F). As a guideline, every 8°C (15°F) rise in temperature will cut the battery life in half. VRLA, which would last for 10 years at 25°C (77°F), will only be good for 5 years if operated at 33°C (95°F). 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #581671 Fri May 31 2019 7:56am
