Home > Wheels & Tyres > What do you guys think of these wheels?
Page 1 of 3 123>
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Got an excellent deal on these wheels for my 2010 RRS S/C Just wondering if anyone is running them and what their opinions are.
[/img]
Post #581495 Wed May 29 2019 3:59am
Brit Plumber
They look a nice design but being made in China, they are likely to crack in my opinion. They may even not be rated to the weight of a RRS, they are after all about 1 Ton heavier than other Jap SUVs. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581503 Wed May 29 2019 8:05am
Tyrefitter
One word CRAP Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #581505 Wed May 29 2019 8:17am
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Rolling with laughter
Post #581507 Wed May 29 2019 8:42am
Tyrefitter
The amount of Chinese wheels we get in with cracks,buckles is unbelievable even Khan are Censored .The only aftermarket wheel I recommend is Hawke from a company called Sixonetwo,ive got a set on my sport & this is the 4th sport ive had them on & I take them off regular to clean them & I always put them on the balancer to check them & they still run true,you can tell by the weight of them when you pick them up without tyres on & the Chinese ones are a lot lighter so not as strong. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #581508 Wed May 29 2019 8:54am
CANROVER
Thanks to those who offered constructive opinions. Regardless, they are here and instead of just assuming they are crap I’ll post in a year and let you know how they hold up. I totally understand the preconception that being Chinese wheels they may not take into account the weight of a Range Rover but you never know. They will strictly be summer tires so no winter conditions for these babies 🤪
Post #581533 Wed May 29 2019 5:47pm
Spangler
IMHO I would listen to Tyrefitter, Understand you have purchased them already but I would have asked for advice beforehand. Look forward to your update in 12 months time and good luck with them. Thumbs Up
Post #581538 Wed May 29 2019 6:03pm
Autobiography1969
I bought a set of 20's for the winter and yes they are in the bracket of "CRAP" as some would put it..
They have been on the car now for nearly 7 months,
just about to change them back to my summer wheels..
I have only done about 3k miles but they are as new condition..
Give them a really good wax or a ceramic coat before you put tyres on them,
this should help keep them clean and easier to clean when on the car..
Go for 275/45/20 I went for 40's and they look a little small..
Enjoy..its your car you put what you want on and in it..
once you stop smiling its time to change something or change the car.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #581540 Wed May 29 2019 6:10pm
Brit Plumber
According to this site they are out of business so if they are cheap, it may be worth getting a spare just in case.
https://www.liveabout.com/toughest-afterma...id-3234451 2019 5.0 SC SVA (Current)
Post #581547 Wed May 29 2019 6:35pm
Tyrefitter
As Autobiography says,polish them then wipe them down with panel wipe then put a coating of Gtechniq C5 on them & leave to cure for 24hours in a dry place & they will be a doddle to keep clean plus it protects them against brake dust etc. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #581548 Wed May 29 2019 6:42pm
Spangler
It wouldn't make them any stronger though so I'd be wary
Post #581554 Wed May 29 2019 7:22pm
Standard LR wheels have their load rating cast in to the back of one of the spokes. Do these aftermarket wheels? Do they have any information on the back of the spokes? 2012 SDV6 - it's missing a couple of cylinders
Post #581563 Wed May 29 2019 11:07pm
Autobiography1969
What is the load rating of a LR wheel?
Would be interesting to compare.. ===========================================
Post #581565 Wed May 29 2019 11:15pm
I have a set of genuine 21" SVR rims on mine and they are rated at 950Kg.
Post #581569 Thu May 30 2019 2:13am
Autobiography1969
The winter ones on the car now are 850Kg from the advert will double check next week when I swap them.
The summer ones are 860Kg from the actual wheels..
so a little less than yours but so far all good..
And I suppose at least I have a back up set if I break some..
Reading up you should take the overall axle weight,,Anyone ?
and divide it by 2..
That number is the minimum Load Rating per wheel..
So axle weight needs to be no more than 1,700Kg
Is this correct??
Maximum mass on each axle (rear) (kg)‎: ‎1,775
Maximum mass on each axle (front) (kg)‎: ‎1,500
If so you take the higher number and divide by two..= 887.5Kg
So I am a little under on both..this opens up to a higher risk,
of cracking and bending..
If yours are the same CANROVER just check them over a few times a year,
I am sure you would notice if you had a large crack.. ===========================================
Post #581640 Thu May 30 2019 6:57pm
Page 1 of 3 123>
