Home > Technical > Low battery
markymarkf
Low battery
Is this anything to worry about SVR Carbon Edition in Estoril Blue MY 21.5
P400e HSE Dynamic full on black with black pack, Meridian surround sound, Fixed Pano roof.
Past MY17 SDV6 HSE Dynamic Yulong White and ivory leather.
Post #581078 Sun May 19 2019 12:48pm
markymarkf
Apologies that you are upside down taken on a mobile SVR Carbon Edition in Estoril Blue MY 21.5
Post #581079 Sun May 19 2019 12:49pm
Do you do lots of short journeys? You need to charge the battery. Get a decent battery charger such as a CTek unit. 2012 SDV6 - it's missing a couple of cylinders
Post #581082 Sun May 19 2019 1:22pm
markymarkf
That's what's strange I've done 1,000 miles last week including a 300 mile drive yesterday so was surprised when this came up.
Thanks for the advice SVR Carbon Edition in Estoril Blue MY 21.5
Post #581088 Sun May 19 2019 3:01pm
Brit Plumber
I get this when I’ve had the radio on without the engine for about 10 minutes. Still get it with a new battery and read (for my car at least) that it’s correct. Has yours just started doing this? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581099 Sun May 19 2019 8:13pm
markymarkf
Yes it was just this afternoon when I got in it SVR Carbon Edition in Estoril Blue MY 21.5
Post #581100 Sun May 19 2019 8:27pm
Lindab
I had a lot of problems with Low battery warning. Even after Ctek charging it was still coming up with this. Changed both batteries last year but it soon came back & was driving me mad. The car was in the main not used much & doing short journeys, not the best conditions for a healthy battery, but Ctek should have kept it up. I also have an F type which was taken off the road at the end of October till the beginning of May & had a Ctek on constantly. No problems, started first time & stop/start worked from the off. A couple of weeks ago I put the Range Rover into an Auto electrician who diagnosed a parasitic drain. He had it for 4 days until he tracked down the fault. Obviously he was not working on it full time as he was checking something then had to let the car go to sleep to see if that was the fault or not, then do the same again. Since I got it back it has not been on Ctek, no warning messages & stop/start is working as it should. (Hope I have not jinxed it by saying its fine Smile Sad ( So dont change the battery, but get an Auto electrician to look at it, not the main dealer as they will just sub contract the work but add their cut. That is unless its still under warranty, but when I initially asked them about it they said drive it more so they are clueless. Hope this helps Thumbs Up
Post #581103 Sun May 19 2019 9:42pm
Tyrefitter
I got it all the time after I installed the dashcam,its the stop/start battery that causes it,i used to do 200-300 mile & it was still showing after I turn engine off.In the end I just ignored it.Even after charging battery up for a day it made no diffence. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #581105 Mon May 20 2019 7:01am
