Home > Technical > 2012 RRS (1piece tailgate) - Boot sticking ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Have a look at this in my gallery File 1 03/05/19, fitting instructions for original version, if new one now plug and play should be even easier as no soldering wires.
Fri May 03 2019 9:51pm |
Out of curiosity operated the buttons on mine twice in quick succession and that releases the tailgate lock, it then stops opening, if I press button twice but a little slower it opens then closes again, does the same on all three buttons, fob, dash and tailgate never ever noticed before, but then again don't recall ever pressing the buttons twice. But as I say though nothing to do with my original problem as was doing it before mod fitted. Cheers Col |
Fri May 03 2019 10:22pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 471 |
Thanks Col.. A bit of light reading.. yes the new one is plug and play,, so as you say should be a bit easier.. =========================================== 2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar, |
Fri May 03 2019 10:39pm |
It takes longer to remove the back panel than it does to fit the device. Just don't use the sticky pad wire fixings as mine kept falling off so gave up with them. 2019 5.0 SC SVA (Current)
Sun May 05 2019 10:03pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Ok tried opening the boot again yesterday with the key. Same thing again , opens a little bit then stops.
Mon May 06 2019 12:07pm |
Ok Managed to get some time to do this today,
Sun May 19 2019 10:42am |
Ok a few weeks on..
Fri Jun 07 2019 11:13am |
You could try cleaning the strut inner (piston?) with a spirit or similar and then lubricating. My struts started making annoying noises so I cleaned and applied Vaseline then opened and closed the tailgate to work it in. There has to be a resistance sensor as it stops opening if it hits an object or the person opening stops it. Perhaps friction in the hinge and strut is tripping this sensor or your struts are tired and losing power. My struts were replaced under warranty before I purchased the vehicle so I’d imagine if yours are original, they could be tired. 2019 5.0 SC SVA (Current)
Fri Jun 07 2019 7:54pm |
I think im gonna try the Struts next .
Mon Jun 10 2019 10:04am |
Have you tried cleaning them?
Mon Jun 10 2019 12:17pm |
Ill be honest , Its so Random i dont even know when it will happen again so might just replace the struts and hope for the best.
Mon Jun 10 2019 2:06pm |
