Home > Faults & Fixes > Fault code P0730-00 (6D) transmission fault
Ginge
Having this problem and no one seems to be able to get to the bottom of it so here goes! When the rrs is cold it drives and changes gear fine but once it's warmed up I get "transmission fault" and F appears in the display. It's been to 2 separate garages and I need help as they can't seem to give me an answer. Would a flush cure the problem or is it terminal! Car has only done 88k. Changed the transmission oil but still no joy shall I get it flushed???
Post #580989 Fri May 17 2019 3:29pm
Disco_Mikey
It's terminal. New gearbox time...
Post #581000 Fri May 17 2019 4:07pm
Ginge
Is it a rebuild or new gearbox do you think?
Post #581042 Sat May 18 2019 7:21pm
Disco_Mikey
Either, or. Same result, the gearbox needs repaired or replaced
Post #581054 Sat May 18 2019 9:41pm
