![]() | Home > General (L494) > 2016 L494 22” wheels |
Yes they do look like originals.Same as what was on mine when I purchased apart from mine being black.
Jacket2122 Member Since: 06 May 2016 Location: Essex Posts: 13 ![]() ![]() ![]() |
Thank you for your reply Tyrefitter and confirming what I was thinking.
Some of them were fitted with diamond cut faces like yours |
Ive just looked closer at yours & they could be copies as the centre cap is different to any others ive seen on a LR,probably best to try remove one & it should be stamped Landrover on the inside.Unless they are off a Fullfat Rangerover which is the bigger one not the sport. Andy.
I was hoping they were genuine as they do look nice when clean but my spider sense is tingling with these. Which is making me doubt the cars autobiography badge.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
https://topix.landrover.jlrext.com/topix/vehicle/lookupForm
Thanks jimbg,
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Caveat Emptor
Service History
Thanks for the replies,
PM me your reg & I’ll check it for you.you can usually check it’s a AB with the vents in the sides of the rear bumper like in the pic I sent of mine,unless the rear bumper has been changed but I doubt anyone would go that far to change it.Also the rear heater controls on the AB are like these were as the hse usually just have heated seats
Thanks to Andy for checking for me.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Style 508. They were available in 22" in both silver and black from the factory at various points. RRS MY17 SDV6 AB
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1180 ![]() ![]() ![]() |
![]() ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
