Home > Technical > Rear propshaft center bearing... Advice.... 2008 Sport HST
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
So the centre bearing on my rear propshaft has failed. I see you purchase just the bearing but thinking it's best to replace the whole propshaft.
I've seen loads for sale on eBay, internet etc of various brands etc with varying prices. Just wondering if anyone recommends a particular brand I should go for, where from etc. It it a case of I should buy genuine, etc
Thanks
Post #580795 Tue May 14 2019 9:53am
Brit Plumber
Good quality and the correct rating is all you need. Have you time to remove it, get the spec marked on it and then buy the same? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580799 Tue May 14 2019 10:21am
