Home > Maintenance & Modifications > Hissing noise from suspension accumulator
HughN
Wales
It probably originates from taking a hit at some point, but there is a steady hissing noise coming from the air accumulator under the nearside sill on my car. The suspension doesn't drop and it lifts OK, which suggests to me its on the upstream side somehow.
Hopefully, it will be able to go into my local indie this week, but has anyone else had these symptoms?
Also, is there a fitting by which the accumulator can be topped-up with a compressor (if the worst comes to the worst)?
Thanks!
Hugh
Post #580736 Mon May 13 2019 12:09pm
no air addition point.
may need a new tank
Post #580764 Mon May 13 2019 5:15pm
HughN
Wales
Good news all round then, Andy!
Post #580767 Mon May 13 2019 6:04pm
garrycol
Australia
Are you sure it is from the accumulator (air tank) because if it was it would be leaking all the time as it has no "on/off" valves as that is done by the central valve block. If you had a leak the air compressor would not be able to achieve the required pressure in the tank and you would get a fault.
Are you sure the sound you are hearing is not the normal "farts" the car does as it self levels etc - so is system exhaust air that is piped to the rear of the car to its muffler and back to the air compressor area where it vents to atmosphere. I have my air compressor covers of at the moment and the exhaust noise is very noticeable.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #580776 Tue May 14 2019 12:17am
HughN
Wales
Hi Gary,
Apart from when it vents after the car is locked, I haven't heard it 'fart' before.
The hissing definitely sounds like it is at the front of the air tank near the front passenger door (RHD), not around the compressor.
Three days later and the car hasn't visibly dropped. I've just sent my wife a text asking her to go and listen to it. Smile
Post #580876 Wed May 15 2019 11:42am
HughN
Wales
No hissing.
I can't think of anything else in that sort of area that could be hissing. However, I'm not going to take a look without it being up on a proper ramp. Shocked
Post #580884 Wed May 15 2019 3:09pm
HughN
Wales
Sod it - off to the byways of the Lake District I shall go...
Post #580897 Thu May 16 2019 7:19am
