Home > In Car Electronics > Sat nav update advice
mrluke
I remember when i first did mine in 2017, update kept stopping on its own ( despite having the engine on) it finished and looked fine. But i couldnt use postcodes in satnav ( only previous destinations postcodes) .
I then waited for the 2018 update and reapplied and it fixed it all Wink . The second time i just purchased the code and used my own usb stick as i think that was probably the issue.
Post #580718 Mon May 13 2019 8:43am
scarey
any nav updates will default the nav to begium, hence the UK postcodes not working....change search area to UK and all will be fine..
Post #580729 Mon May 13 2019 11:31am
mrluke
That wasnt the problem in my case it had corrupted the install , Mine was already set to GBR.
Post #580730 Mon May 13 2019 11:41am
shepp
I used a 32gb SanDisk ultra flair, 7 quid from Amazon, definitely need a min of 32, the update is 21.5gb. once updated I formatted the usb, now it is used for music. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #580757 Mon May 13 2019 3:50pm
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
After 2 USB from Here car is in having firmware updated, and then they have the care on life support battery over weekend to see if update will load, as after 1.5 hours still showing zero percent.
The thought is that it might find the spot it froze at and carry on, but I am not convinced this will happen.
I don’t suppose there is an upgrade that can be fitted instead of buying another module?
Post #581005 Fri May 17 2019 5:13pm
mrluke
possible worthwhile upgrade
https://www.aliexpress.com/item/Android-4-...9d3cba7451
Post #581577 Thu May 30 2019 7:51am
