Home > Technical > Sensors failure - Hawkeye result
ksorensen
Egypt 2007 Range Rover Sport TDV6 HSE Santorini Black
My P sensors stopped working and my Hawkeye tester came up with this result, is it the sensors that are failing or the power to the sensors?
Post #544422 Sun Dec 31 2017 12:07am
Could be short behind the bumpers
Or a sensor.
If you have no luck. Disconnect front bumper loom.
Clear codes.
Put car in gear
Park brake off.
Then rescan codes and see what u now have.
Post #544424 Sun Dec 31 2017 6:06am
ksorensen
thanks for your reply - I will try remove the bumper next weekend
Post #544516 Mon Jan 01 2018 3:19pm
ksorensen
Final result
Hi
Sorry for the late response, but it was this weekend I finally got the time to look at the problem. (yeah - a year and a half later, I know Smile )
I changed the sensors and Voila!!! the Parking Aid are back in business again Smile
i didn't take the front bumper entirely of, I only removed the screws and titled the number enough to get to the sensors.
The rear sensor was right out sensor, and it is possible to change without doing anything with the number at all.
The Hawkeye fault reader did its job, and it would have been so much more difficult without it.
Post #580661 Sat May 11 2019 2:03pm
