Home > General (L494) > Bonnet vents
MBRRS
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Java Black
Bonnet vents
How do you remove them without damage ??? The name’s Bond ‘ James Bond’
Post #580581 Thu May 09 2019 5:55pm
Red Arrow
Plastic wedge type trim tool and a microfibre cloth , i also put some masking tape on just in case .
Very easy to remove Thumbs Up
Post #580591 Thu May 09 2019 7:18pm
MBRRS
Thanks I’ll give it a go. The name’s Bond ‘ James Bond’
Post #580592 Thu May 09 2019 7:30pm
Tyrefitter
Another tip,don’t try to remove them in cold weather as the plastic tabs tend to snap off,when I’ve removed them in the past I usually warm them with a hair dryer or heat gun which makes them easier to remove. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #580593 Thu May 09 2019 7:47pm
Eaters
This might help:
 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #580622 Fri May 10 2019 3:39pm
Tim in Scotland
Robin, L494 doesn’t have the same side vents - it has a tiny trim fake “vent” on each wing and two large vents on the top of the bonnet that on some models vent hot air out. The air intakes of an L494 are cleverly integrated on the wing top but under the edge of the clamshell bonnet so it is very difficult to get any water down them.
Wing and bonnet vents on L494
 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #580623 Fri May 10 2019 4:14pm
Eaters
Whoops. Thanks Tim. No excuses just ignorance on my part. Embarassed Robin
Gone:
MGZTT 190 2.5
Post #580625 Fri May 10 2019 5:01pm
Tyrefitter
Another tip,if it’s the L494 vents then the ones on the wing,get some fishing line or something similar & slide it along the 2 fins that go to the rear of the vents as they are held on by double sided tape Wink Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #580626 Fri May 10 2019 5:07pm
