Home > Technical > Anyone with SDD
derekmines
Anyone with SDD
So I'm going to install my towbar and electrics tomorrow and apparently SDD is needed to tell the car that the kit is there and disable parking sensors etc.
Anyone in the SW able to make this change in exchange for a beer token or two?
Post #580547 Thu May 09 2019 8:34am
Brit Plumber
It’s not exclusively SDD but as most other diagnostic systems are locked to VIN or require a multi vehicle subscription it may be a better option. Or if someone can lend you a GAP tool you could pay the fee for an extra vehicle to be added. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580555 Thu May 09 2019 11:51am
derekmines
Happy to go with whatever option works easiest to code the setup to the car, hopefully someone local-ish can assist
Post #580570 Thu May 09 2019 3:06pm
Brit Plumber
Have you thought about buying a pass through? I bought a good quality copy that uses Chinese components built in the USA and an live SDD. All in was £190 but I think you could get it a little cheaper.
I have the GAP IID in the glove box as it’s easy to use and connects to my phone via BT. I can use it in minutes pretty much anywhere so it’s a good bit of kit but it wont do everything. I have SDD for more in depth fault finding etc which it’s good at but it takes a bit of setting up and drains the battery like you’ve never seen! 2019 5.0 SC SVA (Current)
Post #580579 Thu May 09 2019 5:53pm
aljo
Brit P do you have a link to the SDD equiptment and software you purchased Thumbs Up
Post #580597 Thu May 09 2019 8:53pm
Brit Plumber
I’ll PM you, may take me a bit to find the details so bare with. 2019 5.0 SC SVA (Current)
Post #580600 Thu May 09 2019 10:17pm
aljo
Cheers mate 👍
Post #580613 Fri May 10 2019 9:29am
RRSporter
Hi Ditto to the OP. Anybody in South East able to spare 10 mins of SDD to enable towbar logic on 2016MY Sport? Or is there are reasonably priced system that I can invest in? Earlier SDDs are no good I'm told...
Failing this its off to the dealer £££ 3.0 SDV6 HSE L494
Post #581815 Mon Jun 03 2019 8:09pm
RRSporter
Obviously not! Ok i the system is fitted and operational after I eventually discovered how to initialise it. What exactly is SDD telling the car, does anybody have any technical info?
I’m assuming it may include disabling rear parking sensors, maybe adjusting shift patterns etc? I’m trying to understand how urgent this programming is as at garage as it doesn’t seem anyone in the South east can help with this little task?
Thanks 3.0 SDV6 HSE L494
Post #582043 Sat Jun 08 2019 7:51pm
derekmines
As far as I understand it the coding will
Turn the reversing sensors off
disable the car's rear fog light
stop the car from entering certain suspension modes
That's about it I believe, certainly I've had no issues towing so far and I too am yet to find anyone with coding ability
Post #582046 Sat Jun 08 2019 8:43pm
RRSporter
Cheers Derek
Ok a local Indy isn’t sure he can do it on his kit but is willing to try so I’ll report back if it happens 👍 3.0 SDV6 HSE L494
Post #582052 Sat Jun 08 2019 10:46pm
RRSporter
Predictably all indies wanted car booking in etc etc. £100 at LR for basically plugging computer in and sending a file to it. Anyway rear sensors silent when tow plug inserted and car cleaned throughout. It least I didn’t pay them £2k for deployable towbar 👍 3.0 SDV6 HSE L494
Post #593128 Fri Jan 10 2020 8:24pm
Brit Plumber
They don’t even load a file, it’s just turning the option on. But I wouldn’t worry or rush to get it done. 2019 5.0 SC SVA (Current)
Post #593182 Sat Jan 11 2020 7:28pm
