Home > Technical > RRS dreaded EPB fault |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
Strange your getting no response when activating the switch,, have you checked the fuse for the EPB.? or even the wiring for any signs of damage. Flashing light indicates a fault on the system rather than adjustment issues I think,, not sure if it requires a reset of any kind after maintenance but the tool of choice for doing this would be the IID tool as used by most people on here,, I think it's one of the few that are designed for the RS. 2010 RRS, TDV8
Wed May 01 2019 6:31am |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 |
Hi..
Wed May 01 2019 7:16am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
The IID tool is often talked about, and can be bought new from people such as Dan at Duckworths LR dealer. There are 2 versions, the newer ones are bluetooth to your phone, and I think the old ones are plugged into a laptop (never used one so just going on what I see here). They also come up second hand for example, and I understand they have to be registered to your car at an additional cost.
Wed May 01 2019 7:46am |
What happens if you press and release the foot brake 3 times holding it down on the 3rd and then pushing down on the EPB switch for 5 seconds? 2019 5.0 SC SVA (Current)
Thu May 02 2019 8:01am |
Hi.
Thu May 02 2019 8:51am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
For info...
Thu May 02 2019 8:05pm |
Thanks for letting me know but I ordered the icarsoft lr2 which has good reviews and will hopefully read and clear the EPB error code |
Thu May 02 2019 8:26pm |
Let us know what the DTC is when you find it. 2019 5.0 SC SVA (Current)
Thu May 02 2019 8:37pm |
Hi All..
Fri May 03 2019 6:08pm |
FIXED..
Mon May 06 2019 11:29am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Thanks for feeding back Mark. Hopefully this will help others in the future Kev
Mon May 06 2019 1:27pm |
K!AN1 Member Since: 15 Jul 2021 Location: Reading Posts: 20 |
Old thread i know, but no point starting a new one. I'm in the same position, however, i cant figure out how to access the EPB? Would i be right in assuming the vehicle would need to be in offroad height? would that give me enough clearance? although, i have a rounded not on the bracket I've been fighting for 3 days !! |
Sun Jul 18 2021 10:03pm |
