![]() | Home > Technical > Yet another TPMS question. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If you do get it to work it is a pretty useless system on the RRS1 as all it does is let you know if a particular tyre has dropped below around 25psi. that's it, you can't check pressures or anything else. I guess it is better than nothing but only just, there are far superior aftermarket systems out there.
I have heard it’s pretty useless but after finding one tyre at 15 PSI I became paranoid so I’m always checking now. As the wiring is present and the parts are cheap I thought I’d retro fit it. It looks identical to the type fitted to the Ford Mondeo which I found worked quite well and displayed a reading so it must be the LR software which didn’t include this capability. 2019 5.0 SC SVA (Current)
The bit's you mentioned are all I have ever seen on mine, but to be fair I haven't been looking for anything else, but do have a vague recollection there could be something else up by the spare wheel but may be another antenna for the spare, however may have imagined that. Make a note of the sensor serial numbers and which wheel before you fit them as I believe you can enter them manually using diag. tool if it does not recognise them although it should do it automatically after a run. |
Got it sorted, took a little guess work to get the correct CCF but it appears to be working. 2019 5.0 SC SVA (Current)
