Home > Maintenance & Modifications > Removing tow bar
HughN
Wales
Removing tow bar
I want the tow-bar off my car. I don't need to tow anything (and I wouldn't trust it anyway) and it's a pain off-road. A new key didn't work so I have drilled-out the tumbler and the rivet holding the cover on the other end. The splined shaft cannot turn the gear inside the mechanism, presumably because it is seized up. The teeth on the mechanism look a bit weedy.
Enough penetrating oil has gone in that the price of crude has gone up a couple of dollars. Gert big smites with a hammer haven't helped free it.
I don't suppose anyone will want to gas-axe it when it is that close to the fuel tank and brake lines. Before I take a disc-cutter to it, can anyone think of anything I haven't tried?
Thanks,
Hugh
Post #580244 Sat May 04 2019 1:18pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
if you have removed the lock
the shaft etc
then you just need to drift the pin through from the rear side.
i'm sure there are similar threads on here also 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #580252 Sat May 04 2019 2:31pm
Brit Plumber
As MGO has said, a big drift or drift substitute and a hammer, it will go. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580266 Sat May 04 2019 5:45pm
As said, if you take the spare wheel right out of the way you should be able to give the seized pin/shaft a fair wack with a lump hammer and drift.
Post #580277 Sun May 05 2019 6:10am
HughN
Wales
Thanks chaps. Thumbs Up
Off into battle I shall go...
Post #580330 Mon May 06 2019 9:28am
