Home > Technical > fuelpomp change in fueltank
Patrick
Belgium 2006 Range Rover Sport TDV6 SE Baltic Blue
Anybody had changed this pump yet on his RRS? I must change mine the RRS starts but two seconds and stopped working try to start and would not start after 2 min he starts again.Can I change the pump from inside under the seat ore must I get the fueltank out underneed the RRS!
Thanks for your respond and id's
Post #579863 Sun Apr 28 2019 5:18pm
Cutting a hole in the floor to access it used to be a trick with the old P38, not sure you can do it on a sport, I think it's a tank out job or at least lowered.
Post #579890 Sun Apr 28 2019 11:52pm
get the fuel level low
and then lower the tank.
If the tank cage is very very rusty/weak you may need a new one
Post #579901 Mon Apr 29 2019 11:04am
