![]() | Home > Maintenance & Modifications > 2011 RRS Supercharged Brake Pad Tutorial Videos? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Download workshop manual from here, should have all you need.
Rears are TRW on the Supercharged. I’ve just done mine and you only need the WS Manual or Bodsys Brake bible. If you’re doing the discs to, it’s a little more complicated. 2019 5.0 SC SVA (Current)
joshuaman Member Since: 26 Apr 2019 Location: New York Posts: 3 ![]() ![]() ![]() |
Thanks mates, what does TRW mean? just doing pads this round |
TRW is just the make of caliper, unless you already have them might be worth trying to get some EBC redstuff brake pads it will get rid of that annoying light braking squeal they suffer from.
ahh appreciate it. Downloaded the manual. Looks like it will help for the rears. i cant beleive no video of rear pads being done unless they are the same as the non supercharged maybe??? and only the fronts are brembo? |
I think the rears are the same procedure as non s/c, I believe the it's just that the s/c may have 365mm rear discs and non s/c are 355mm if I remember correctly. |
I think Cols got it spot on. I think all models are basically the same, just a different size but the procedure is the same. Pads will take about an hour. 2019 5.0 SC SVA (Current)
