Home > Maintenance & Modifications > L320 'Check Brake Pads' Warning.
HughN
Wales
My car's had this message a while but all pads and discs are fine. Today I found that the wire so the sensor on the n/s/f wheel had popped out of one of the clips and had rubbed on the suspension to the point of exposing the conductor.
Question: does this message have to be cleared via a computer, or will it clear itself when the car is convinced it is no longer a problem, i.e., time / distance driven?
TBH, its tempting to cut the wire and check the pads visually.
Thanks,
Hugh
Post #579254 Fri Apr 19 2019 11:41am
It will clear itself.
Wires need to be joined to turn fault message off
Post #579255 Fri Apr 19 2019 12:04pm
HughN
Wales
Post #579256 Fri Apr 19 2019 12:16pm
