![]() | Home > Tips & Tricks > Revitalising the scuttle panel that has turned white |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Very Nice job.. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Looks good, how is it fastened on? I don't suppose you took any pictures as you took it off? |
It's just held on by clips. You first need to take the A-pillar trims off, then the wiper arms and then the scuttle. Kev
Sounds reasonably easy. A job to do if you are having the screen replaced as well. |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Do the A-pillar trims just pop off aswell? I've been meaning to do this for a while now (since getting the RRS 2 & 1/2 year ago.... ![]() 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Buzzweld. Plastic In One |
If you do remove the A-pillar trims it might be worth getting a few spare clips first as it is not unknown for them to break when trying to release them.
A pillar trims are also clipped on and as Col rightly says, the clips do snap. I replaced all of my clips with new ones because the seals on them looked a bit iffy.
By the way, I'm not sure if anyone has noticed yet but looking at my pictures I placed the masking tape above the wiper but when reinstalling, I aligned them to the top edge of the tape |
Same for the horrible grey tailgate button...
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 919 ![]() ![]() |
Gtechniq C4 for all black trim. Gives as new appearance |
Does that work on the scuttle panel that has gone white though Linda? I've read that it doesn't bring it back. Kev
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
I used C4 on mine and it looked like new but it didn't last more than a few months before starting to look faded again so tried it again thinking maybe it needed to build up with a couple of coats but 6 months later and it's back to faded again.
Thanks for clarifying. I'm going to get hold of some to use on the A and C pillars. How long does it last on there? Kev
