![]() | Home > General > Dual screen |
I’ve done it on my 2012 with the screen and control from a 2013 and I’m pretty sure the 2014 uses the same Gen 2.1 front FCDIM. Does the 2014 have soft keys or hard keys to activate the Dual view? Your manual should show this. You will obviously need a FCDIM (Screen) and change at least 3 files in the CCF. 2019 5.0 SC SVA (Current)
Dizzydog Member Since: 03 Apr 2019 Location: Somerset Posts: 6 ![]() ![]() |
Hi Brit Plumber, according to the manual it’s a soft key,
FCDIM is Front Control/Display Interface Module. That’s the screen. The L320 has a hard button to select Dual View and a soft Key to exit. If the L494 only has a soft key then it should only need the Dual View FCDIM and the CCF edit, that’s the car configuration file, this file switches on all the options you have and hides what you don’t have. You would need someone with or your own IID tool, VCM2, black box solutions or similar tool to activate. 2019 5.0 SC SVA (Current)
Thanks for clarifying that, I’ll try and find somebody locally with a IID , and hopefully the screen will support dual view!
You’ll need a new screen as they are physically different, the existing screen isn’t capable of dual view so you will need to find a replacement. Can you PM me your VIN and I’ll get you a number to search on eBay. 2019 5.0 SC SVA (Current)
Cheers for the help Brit Plumber! |
Rs4-cab Member Since: 01 May 2021 Location: Northampton Posts: 4 ![]() ![]() ![]() |
Hi Brit plumber
Install is easy, swop out the FCDIM and the panel, no wiring mods required. The screen is slightly smaller than the standard unit so has its own bezel.
philaldred Member Since: 09 Apr 2019 Location: Stockport Posts: 3 ![]() ![]() ![]() |
Sorry to dig up and old thread...
No problem, for dual view alone, you just need a dual view screen ( FCDIM) and the control panel with the dual view button.
I'm definitely interested in the dual screen but also the RSE, if you by any chance know what parts I would need for both I would appreciate it. Happy to chat via PM or other means. |
