Home > Faults & Fixes > Need some knowledgeable advice please! - main dealer no fix! |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
Has the battery / alternator been tested ? Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Thu Apr 04 2019 6:25pm |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
Apparently so and all ok - when i spoke to the tech i mentioned all the possibilities i have read on this site and he knew all about them and gave the ok... |
Thu Apr 04 2019 6:29pm |
Thu Apr 04 2019 6:41pm |
@riverblanche
Thu Apr 04 2019 6:55pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Instrument pack is known for giving those very issues |
Thu Apr 04 2019 9:08pm |
Disco_mikey - can u explain more before i talk to dealer tomoro? what do u mean by instrument pack? apologies for ignorance..... |
Thu Apr 04 2019 9:22pm |
I to would concur with Disco Mikey, search this forum and you will see similar threads. The only other thing to check is, if you have a sunroof, check the passenger side carpet. Not the Matt, the carpet and look for dampness. If you don’t have a sunroof, don’t look for dampness and start looking at the instrument pack. 2019 5.0 SC SVA (Current)
Thu Apr 04 2019 9:38pm |
http://www.rrsport.co.uk/forum/topic38922.html?highlight=dials 2019 5.0 SC SVA (Current)
Thu Apr 04 2019 9:44pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
Just to add my 10 pence into the mix,, there has been a lot of posts in the past of people fitting cheap bulbs instead of the likes of osram and this has caused all manner of issues. Could any of these have been changed prior to you taking ownership??. 2010 RRS, TDV8
Fri Apr 05 2019 10:06am |
Well I finally got the car back on Saturday after 16 odd weeks in the main dealer. All seems good and the car is driving very well. Had the following replaced F.O.C - anti roll bar module, transfer case module, ABS module, rear brake lines BUT none of these were actually what created the issue.
Mon May 27 2019 5:27pm |
Nice to hear you got a good result,,, your right in saying there are a lot of helpful people on this site 2010 RRS, TDV8
Mon May 27 2019 5:53pm |
cheers pal. |
Mon May 27 2019 6:09pm |
