![]() | Home > General > Rattling Diesel... Normal? |
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 188 ![]() ![]() |
That’s odd. Mine has just started to a
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
Before my current RRS I had a FFRR Westminster. I only had it for a month as it kept throwing up an EML due to an EGR issue that the Main Dealer failed to sort. Strangely, it also had a raucous metallic rattle under hard acceleration that bothered me. It was my only venture into the V8 world and was part of the reason I swopped it for my current car. I have always wondered if it was normal as the car went like greased weasel s..t. Maybe I should have just got used to it? |
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 ![]() ![]() ![]() |
This is exactly where I am on this; I just don't know it it's "normal"...
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
My TDV8 rattles it head off very badly at times and yet other times its as smooth (almost) as a petrol. It is not consistant. Only 37,000km on the clock (23,000 miles).
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Have you tried running on the Super Diesel? If the rattle you're referring to is diesel knock, then you may find it disappears with the better fuel.
Could this be a vanos rattle? Is that common on a TDV8?
The TDV8. sounds like a "Mack Truck' on the outside, its normal. Inside its a different story but you can still tell its a diesel.
Must admit never noticed any rattles on mine, smooth as owt for want of a better description whether it's from cold or not,,, not that I have a trained ear mind. It's coming up to 105k on the clock, I've had it nearly 6 years now and never let it run more than 5000 mls without changing it, always using castrol oil. Always use Asda fuel but most times also add Millars diesel ecomax additive, never had any issues with gummed up or fouled MAP sensors, always starts fine. 2010 RRS, TDV8
