Park Brake Requires Calibration
Does anyone have any experience of this?
Applying foot and park brake as suggested does not seem to fix it and the downside is the park brake stays on.2014 RRS AB Santorini Black
Sun Feb 03 2019 6:34pm
holmesy84
Had it on my old evoque, most of the time I got rid of it by doing the steps it states. Eventually it happened at a petrol station and wouldn't shift so had to get Land Rover assist out. By the time he got to me it had disengaged, the guy couldn't find a fault code but told me to take to the dealer in the morning. The dealer did some checks and put it down to a wire/clip being damaged which they replaced and never happened again.
Sun Feb 03 2019 7:48pm
Mike London
Error message changed to “Park Brake Fault” ... although it was still drivable if the park brake was not used.
Eventually managed to get it booked in with my local LR dealership who identified a faulty brake actuator which was replaced.2014 RRS AB Santorini Black
Tue Apr 02 2019 3:04pm
mannchris
I had this, after waiting for an hour for recovery I had a call from "LR" the procedure is to actually push the EPB down and up again 3 times, then you can drive away. Apparently due to contamination between pad and disk?
I was on the top floor of multi-storey so recovery van couldn't get to me due to height restriction!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
